11th Avenue
Re: 11th Avenue
Post by Mike_R » Wed Sep 18, 2013 8:03 pm
The corner module, now named Causeway, is coming along.
First is the snow phase, when it all gets covered with ceiling paint. The track is protected by masking tape.
It now stands on its own legs, a new method of single legs clamped in a socket has been used. If stable enough I might put these on other boards as they take up little room for transport.
Finally a view of the causeway, with rocks now stained.
Re: 11th Avenue
Post by Mike_R » Thu Sep 19, 2013 7:14 pm
Another day on Causeway's construction. This will probably be the last before Saturday's meeting. I'll see if I can get 11th Avenue's tower fitted tomorrow.
It now has static grass, FMR's small applicator and Woodland Scenics grass.
I've fitted the culverts, 16mm flex conduit, one can be seen through.
A potential photo opportunity. I really need to make a plain blue backscene to hang behind modules!
Re: 11th Avenue
Post by BrianMoore » Thu Sep 19, 2013 11:12 pm
Looks great, Mike. 25 points awarded.
Re: 11th Avenue
Post by PeterLJ » Fri Sep 20, 2013 7:38 am
Hi Mike
Looks great, remind me are we seeing it on Saturday?
Re: 11th Avenue
Post by Mike_R » Fri Sep 20, 2013 10:13 am
PeterLJ wrote:Hi Mike
Yes it will be at the meeting, we need it to turn Wolter Springs across the room. With both at the end of one route, they can be tested and debugged without affecting the rest of the layout. Hopefully they work first time and add to our operations.
Re: 11th Avenue
Post by Gloriousnse » Fri Sep 20, 2013 10:17 am
Cool - see you guys tomorrow sometime! :)
Re: 11th Avenue
Post by Mike_R » Fri Sep 20, 2013 10:26 am
Just seen that Brian has got a video of the junction module on Model Railroader's site.
http://mrr.trains.com/videos/user-video ... m_content=
Re: 11th Avenue
Post by Mike_R » Thu Sep 26, 2013 8:47 pm
After working on the East end, now to changes at the other end. I'm shifting platform 3's track across to allow a full platform, it used to line up for the third track on the old modules.
The original view of the west end.
The track has been removed, along with most of the upper level support columns.
The new track in place.
The new platform, cut from Sundeala, luckily I had an off cut from when I laid the originals over 10 years ago. Never throw anything away!
The filler that I coated them with hasn't lasted, so I'll need to buy another tub.
A new board, probably the old 2' that used to fit on the end will be going on the end of the layout. Platforms 1 & 2 will terminate, only 3 will continue through to the end of the layout. This also makes the yard tracks longer and will make the module able to run as a through module.
Loco hauled trains pull into platform 3 and are the stock is then pulled out and placed into 1 or 2.
Re: 11th Avenue
Post by torikoos » Thu Sep 26, 2013 9:53 pm
You are moving along steadily Mike, only just heard about your intentions last meet, and action is already in full swing. Looking forward how it goes on from here.
Re: 11th Avenue
Post by Mike_R » Sun Dec 01, 2013 10:12 pm
More work has been done to the new station. One of my old 2' boards built for the old three track standard, which used to fit on the end of this module, saving a lot of work. I removed the three old tracks, the yard tracks remain, just straightened.
The new platform three track, which will allow 11th Avenue to become a through module was installed followed by new platforms and a base for the station, a mockup of which can be seen at left.
The card foundations for the building are now in, the tracks are covered to allow a fine filler to be spread on the platforms. 2mm acrylic sheet forms the street at the right edge.
Re: 11th Avenue
Post by Mike_R » Sun Dec 08, 2013 10:03 pm
11th Avenue's platforms are now finished, and I've ballasted the tracks. The photos show the card mockup of the Walthers kit that will go here.
The front of the station.
The rear with the longest platform, no3 for arrivals.
Re: 11th Avenue
Post by BrianMoore » Mon Dec 09, 2013 12:46 pm
Looks great, Mike. How long is platform 3? Just musing on whether it could take the arrival of an Amtrak terminating train that could be switched and turned around to go back to staging.
Re: 11th Avenue
Post by Mike_R » Mon Dec 09, 2013 2:11 pm
Platform 3 is 6' long, 1 & 2 4' long.
The idea is a loco hauled train would pull into 3. The stock would then be pulled back and placed in 1 or 2. The locos can then run back to the loco spur or on to the train for departure. Platform 1 has 2' of clear track beyond the platform so can hold that 6' train for departure. If you don't mind stock being off the platform the train limit is around 8', but would block platform 2 on arrival. Platform 1 could take that train without blocking the furthest crossover.
How long is your train?
Re: 11th Avenue
Post by Mike_R » Mon Dec 09, 2013 2:25 pm
Another thought the train locos can run around 6' of stock, using the freight yard. They can then either push back into platform 1,2 or 3.
Re: 11th Avenue
Post by torikoos » Mon Dec 09, 2013 3:35 pm
I think I'm seeing where this is going :-)
Nothing to do with two F40PH loco's pulling a certain train Brian? ;)
One and two would be great for push pull services, such as the Metro sets we had at Broadclyst, or SP commuter trains, with Bi-level coaches and a passenger GP9 ;)
