I was wondering if we have a recommendation for the type of ballast to be used on our HO NMRA BR Spec boards.
HO Ballast
- BrianMoore
Re: HO Ballast
On all of the Western Union modules so far, there's been the same mix of ballast on everything. So, despite there being different colours and types of scenery being connected up to each other, the effect is far less jarring due to the consistency of the ballast colour, which remains constant.
- warbonnetuk
Re: HO Ballast
Still it would be good to have a rough guide on the shade to be used. From memory RS Tower use a light grey (Woodland Scenics) ballast where as, after some experimenting, we at Seaboard Southern have opted for a granite ballast that comes out a mid / dark grey once glued down. I did a test piece of track as part of the evaluation process and to my eyes there was a noticable difference but that was with no other visual distractions to lessen the impact.
Guess the acid test is that from the initial module linkups that have taken place how did it look? Maybe just need a ban on Pink Lady quartz ballast
Re: HO Ballast
Hi BrianBrianMoore wrote:On all of the Western Union modules so far, there's been the same mix of ballast on everything.
Yes, we had buckets of the stuff, however all gone now!
Re: HO Ballast
Ballast can be lots of colours anyhow, so it doesn't bother me loads if there are some differences.
I really like the colour of the 'salt & pepper' mix that WU have used, but it looks quite coarse to my eye compared to the one we use.
- BrianMoore
Re: HO Ballast
The old adage of using N-scale ballast for HO rings true, as it does provide (to my eye) a more realistically-sized "nugget".Gloriousnse wrote:Ballast can be lots of colours anyhow, so it doesn't bother me loads if there are some differences.
Re: HO Ballast
Indeed, mixing is fine, although I would have preferred if I could have at least 'colour matched' the WU modules with ballast, I do find it a bit coarse.
I've taken matters a step further, the ballast I use on my module (See separate thread) is Z scale ballast, of a brownish mix colour. On my home layout I have a mix of various shades of Woodland Scenics fine ballast (probably N scale), and I use a grey Vivarium substrate for another section that depicts new ballast. This Vivarium substrate has a near similar texture to the Woodland scenics ballast, but is dirt cheap in comparison.
Did the WU use aquarium 'sand' by any chance? That's how it appeared to me.
Re: HO Ballast
I don't know about the others, but I use sieved B&Q sharp sand. A £2, 25Kg bag gives about 6Kg of ballast, a load of sand I use for sub-roadbed and yards and several Kg of small and large rocks, about 18", good for talus. The ballast comes out around 2" to 3" with the sieve and two tea strainers I use. The sand is a bit light in colour, a wash will darken it. It does take a couple of weeks of 1/2 hour an evening to sieve a 25Kg bag, but it is really cheap.
