Re: Blue box SD40-2
Posted: Tue Nov 17, 2015 9:00 pm
looking forward to the progress you'll be making with this one. Show us how you'll get on with it!
A Forum for Members of the NMRA British Region
https://nmrabr.org.uk/forum/
A sugar cube will easily fit above the rear truck firing down (so 'glue' it to the shell with a bit of silicone sealant, which will make it easy to remove) as do other types of speakers. There are many designs that are 18mm wide, which is about the maximum that will fit inside these narrow hoods).catweasel wrote:So far, so good with the SD40-2 loco. New wheels fitted, A-line Mashima fitted, now for the fun bit. I've re-wired the trucks and will put a LokSound Direct decoder in it, above the motor. Obviously hard wired, which shouldn't pose to much of a problem. I want to fit ditch lights, lights etc. but I'm a bit concerned about the speaker type and position. I've got a small speaker I can fit in the cab roof, but I was wondering about a sugarcube type in the long hood above the truck. Any ideas about this please?
Some Conrail locos did have red marker lights (In the class light holes on the nose of EMD standard cab locos), I'd suggest googling for photos of the prototype machine to see whether it's correct and what the fittings looked like.catweasel wrote:I've made a couple of enclosures for speakers to fit above the rear truck in the body,one of which is approx twice the depth, in theory it will increase the bass response. I have another Blue Box shell in Conrail livery which I want to fit full lighting too.This one has 2 red dots painted on each end. I assume these are tail lights? If so, a couple of micro LED's will go in once drilled through. My big question is the headlights. This loco has the Athearn fire in the cab set up. I can knock out the standard lenses and fit LED's in their place,but what about the number boards? If I drilled a small hole through from the headlight LED would it work to allow a small amount of light from the side? Any comments or advice welcome. Thank you.
