A start was made about 11 years ago, as a series of modules designed to fit into the Thamesiders Group "Esserx Belt LInes" HO modular. I foolhardily committed to build Tower 17 at Rosenberg, Texas as a whole half layout. It was therefore built with corner boards adhering to a geometry of outside measurements of 5' 2" by 5' 2". I therefore designed the layout adhering as closely as possible to the trackplan of the prototype location with a degree of shortening. Rosenberg is the topmost section of the attached plan:
Texas Pacific Lines trackplan by mikearnold, on Flickr
However when I started building that part of the layout, I had not then moved house where I could set up the layout completely in a purpose-built log cabin at the top of the garden. Having got the cabin and I could then plan how I could blend Rosenberg into a complete layout. One other key factor was committing build a complete town for Essex Belt Lines to appear at the Ally Pally show in 2013. It was to be 5' 2" by 17' 2" L shape to create one corner. This became Dillon - a fictitous town somewhere in Texas based on the "Friday Night Lights" series about college football. This has been married together with Rosenberg to create the above plan.
The layout measures 36 by 14. What is built so far are all the boards that comprise the outer circuit of the room, including the delta junction at right plus the yard throat and the reverse loops at bottom left and the yard throat at the left end of the yard. The yard through the centre and top connector to Tower 17 at the junction are yet to be started. All track is in place but only juiced as far as the right hand end of Dillon at bottom all the way clockwise to the board immediately to the right (West) of the crossing at Tower 17.
I will post some photos as time permits - I do have a good number already, especially of Dillon. Rosenberg as modelled is not what you might call photogenic. But time will tell.
