Plug then Play
Plug then Play
Post by torikoos » Tue May 21, 2013 7:03 pm
I've taken a picture of the set of connections as used on the NMRA-BR modules of the Western Union, this is the bottom of one of my modules under construction. You'll have to forgive me as not having placed it in line, as Flickr seems to have changed it's interface and I cannot find the usual method of adding the code to embed the image here.... As soon as that is the case, I'll update this post. (NOW Updated).
You'll notice some differences as opposed to the article in Roundhouse, by Tom Winlow. The differences are mainly due to the fact that RS Tower is the nearest group to us, and we are most likely to interface with them.
Plug then play by K2K Koos, on Flickr
You'll see the following connections:
RED Bananas, Track bus connections
Black Bananas, Auxilary bus connections (Tom Winlow's articles uses power pole connections, but it's easy to plug in a special lead with a banana one one end, and a power pole on the other, to connect the two 'systems'. ).
the Grey ST16 is a plug commonly used for halogen lighting. We use them for analog auxilary power, in this case 16V AC (for lights, or locally controlled turnout motors etc)
Finally in the middle is an 8 pole din connector. This carries the Western Union 'X BUS' , basically these are pretty much all signals of a full Lenz DCC system ( most letters that you find on the back of a Lenz Command station, are represented), throttle bus connections are easily branched of these, and as such, the fascia of each of my module boards has at least 2 Din (5 pole) connections for Lenz Throttles.
All that remains now is to plug them in, and the play can begin. :-)
Re: Plug then Play
Post by Mike_R » Tue May 21, 2013 8:32 pm
Here is my version on my adaptor board. The right end connects to my double track module, it has the multipole plug that carries all my track and power busses through the module. The grey cables carry the screened expanded x-bus, as well as the Lenz bus it has the booster bus and feedback bus, this idea came from the Thamesiders.
Re: Plug then Play
Post by torikoos » Tue May 21, 2013 8:53 pm
Ah yes Thamessiders, I could not remember the origins.
Perhaps for those interested, you can post the pin out of the x bus here( I believe it's a PDF?)
Re: Plug then Play
Post by Mike_R » Tue May 21, 2013 9:06 pm
How do you display a PDF? I only have it on my computer, I'll have to see if I can put it on Photobucket.
Re: Plug then Play
Post by torikoos » Tue May 21, 2013 9:16 pm
you should be able to upload an attachment, there should be a 'tab' below the field where you enter a reply to this thread (don't use quick reply, as that has less options), upload it first, then 'place inline' should do it. The option is below the preview and submit buttons..
koos
Re: Plug then Play
Post by Gloriousnse » Tue May 21, 2013 9:30 pm
Mike will need to forward it to you to upload Koos, only web team members have doc upload access at the mo.
Re: Plug then Play
Post by torikoos » Tue May 21, 2013 9:37 pm
Ah, I didn't realise that. It looked like the same upload option as I have on Big Blue / The gauge. (it's available to all members there) . I have it myself but did not want to 'bypass' Mike in doing so... so moving on..
here it is attached. :-)
xbus pinout.pdf
You do not have the required permissions to view the files attached to this post.
Re: Plug then Play
Post by torikoos » Wed May 22, 2013 11:38 am
I've now updated my original post with the picture placed in line.
It turns out that my trouble with Flickr is due to two issues:
-I'm often using an older computer (a Mac with a powerPC G3 processor), and older browser (newer browsers are not available for my hardware) , which up till recently was perfectly addequate
-Flickr has incorporated newer web technology into their site, which means that certain pop up windows etc no longer become visible on my older machine. It works fine on my fairly new work laptop, I guess for now I have to waste more of my boss' time as Flickr left me no choice.
If you run into similar issues, it might just be that your machine is ancient too....
Re: Plug then Play
Post by Mike_R » Wed May 22, 2013 9:20 pm
There is one addition to the pinout PDF, I've added a Cat 5 cable for connection of an Ethernet tester. This connection (not the best way for use of this cable on the layout, as the pairs should be matched to bus pairs) means that the tester picks up the correct bus pin numbers, so if there is a fault it tells you which bus wire is the problem. I now plug one end of the tester in to where the command station is to be connected and then walk around the layout with the other end checking the throttle sockets and last board bus connectors, a quick easy way to check the bus before connecting the command station. I have 5 and 8 pin test leads for checking both types of sockets.
I added track pickups to one end of my Rampmeter box, that is used to check module track polarity and voltage.
These two pieces of test equipment means it only takes a few minutes to check our modules are correctly connected.
Re: Plug then Play
Post by torikoos » Wed May 22, 2013 9:29 pm
Well I will see that put to the test when I finally manage to bring my modules back to the UK. One board is now completely finished electrically, the other is 3/4 of the way there, just turnout wiring and 16V AC to do.
